Use this procedure to configure the device subject parameters to identify the device. The parameters include name, Email ID, company, department, and location of the subject.
- Select Certificate .
- Select the Global Subject tab.
- In CommonName, type the name of the subject.
- Complete the remaining optional configuration to customize the policy.
- Select Apply.
Subject Field Descriptions
Use the data in the following table to use the Subject tab.
| Name | Description |
| CommonName | Specifies the name of the subject sending the Certificate Signing Request to the Certificate Authority. |
| EmailAddress | Specifies the Email address of the subject sending the Certificate Signing Request to the Certificate Authority. |
| OrganizationalUnit | Specifies the organizational unit of the subject sending the Certificate Signing Request to the Certificate Authority. |
| Organization | Specifies the organization of the subject sending the Certificate Signing Request to the Certificate Authority. |
| Locality | Specifies the locality of the subject sending the Certificate Signing Request to the Certificate Authority. |
| Province | Specifies the province of the subject sending the Certificate Signing Request to the Certificate Authority. |
| Country | Specifies the country of the subject sending the Certificate Signing Request to the Certificate Authority. |
| InstallFile | Installs the specific certificate file type obtained offline from the Certificate Authority. |
| InstallFileName | Specifies the certificate file name to install. |
| UninstallFile | Uninstalls the specific certificate file type obtained offline from the Certificate Authority. |
| UninstallFileName | Specifies the certificate file name to uninstall. |
| GenerateCsr | Generates the certificate signing request to obtain the offline subject certificate. |
